Century 3035 / Branson 3520 Side Panels
   / Century 3035 / Branson 3520 Side Panels #1
CEN3035
Chillicothe, OH
Century 3035
I am looking for the side panels for a Century 3035 or Branson 3520, apparently Branson has discontinued making these. Does anyone know of a Century/Branson graveyard or know of where I might find these?
   / Century 3035 / Branson 3520 Side Panels #2
i would check with Panhandle Tractor , out in plainview, tx, his shop also runs the branson West warehouse, if anyone knows where you could source those from he should, and at the very least he may be able to point you in the right direction
here is his shops contact info
Panhandle Tractor
(806) 293-0337
Thanks for the lead to Panhandle, they are going to check Monday to see if side panels from another model might work. There are a few side panels that are similar but not quite the same, so may be worth taking a chance to see if they can be modified to work. 4520 has a slightly different P/N and 4720 has a similar panel that hinges/slides instead of lifting off. Will update when I hear back.
   / Century 3035 / Branson 3520 Side Panels #4
where they able to get you hooked up CEN3035, i had another customer ask me about this, just wanted to see what you were able to come up with.
Asteral, it was good talking with you today. I am going to go ahead and order the side panels for a 38/42/ & 4720 (NTD6870000B0 & NTD6880000B0). I am thinking that a few minor modifications if any will be required. I will let you know when I get them on the tractor. Thanks again for your help.
I picked up my side panels over the weekend. I am going to have to move the lower mounting points to mate up with the tractor connections. A little cut-off wheel work and some welding then touch-up painting. Hope to have them on later this week.
Picture of the new grill and right side panel. Had to remove the lower panel attachment pins as they are in a different location than the originals. Did some touch-up with Rustoleum Cherry spray paint. Versus welding the pins on in the correct location, I chose to modify the lower mount brackets by bending to hold the bottom of the side panels and adding 3/4" ID rubber hose over them to keep from scratching the side panels.
   / Century 3035 / Branson 3520 Side Panels #8
Good work!
   / Century 3035 / Branson 3520 Side Panels #9
Where did you get the new grill? Have not been able to find one for a 4520. Thanks.
I was able to get the grill from a Branson dealer in Kentucky, Cottrell Farm Equipment. They were able to order from the facility in Georgia. This one is P/N NTD610E000A9, it was a bit pricey at $650. It looks like this is the same one as your 4520. It is nice to have better dust protection and head lights though. The original one was pretty mangled up.
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
New Wolverine Hydraulic Shift Pallet Forks (A51573)
New Wolverine...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
