Century 2028 Transmision Problem. Help!!!
   / Century 2028 Transmision Problem. Help!!! #11
We had one 2810 Branson do that almost two years ago. We were sure it was in the trans. It ended up being the brakes, even though that does sot seem to make sense. Back off the brakes and use the tractor and see what happens.
Today was the first day that the temperature has been above freezing since I brought the tractor home, so I decided to give it one more try this afternoon. I used the tractor in both 2wd and 4wd, with and without braking, straight and turning, and in all three ranges for almost an hour and everything worked flawlessly. I wonder if there could be some water or condensation in there somewhere that could have caused this. I figure tonight when it gets cold, I'll try it again. /forums/images/graemlins/grin.gif
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
