century 2028 hydrauics problem
   / century 2028 hydrauics problem #1
rogerdodger
skiatook oklahoma
2002 century 2028
wel back again finaly got a new drive gear (splines were completely gone) and hydraullic pump (which shaft was twisted) for this tractor but need pdf file for repairing have most of bolts out of front gear case but have a question about removal of the throttle cable which is in front of case and also the governor which is on side of case. I dont want to mess something else up at this point. does anyone know where i can find pdf file for this repair? thanks
   / century 2028 hydrauics problem #2
rogerdodger,
I have the chassis/service manual that I could scan the section you require if you're still looking for documentation.
   / century 2028 hydrauics problem #3
Have you determined what caused the shaft to twist?
Were the pump bolts tight when you removed the pump?
Perhaps the pump was deadheaded and the engine continued to run.
You might try and see if all hoses are connected correctly.
Check also to see if there is flow through all the valves by using air to see if air can flow through all the valves to tank.
pdittlysquat,
i could sure use any help i can get and that sounds perfect the guys at tractor sales know parts but not how to repair or sequence in which to disassemble and reassembly of the front case i.e throttle cable and governor thanks for your help
pdiddlysquat,
i could surely use the help i answered you post but ended up making new post u might read for full needs thanks again
yes please thanks please send details from your manual pdidlysqt
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2024 MERCEDES-BENZ SPRINTER 3500XD BOX TRUCK (A51222)
2024 MERCEDES-BENZ...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
