Central Torque Wrench
/ Central Torque Wrench #1
BillyP
Eagletown, OK
JD 4610 ehydro MFWD
I was at this little junk store this morning and saw a Central 1/2" drive torque wrench (0-250 ft-lbs), model 96353. It was marked $50 but could probably get it for $40. Looks to be in good shape but you never know.
My question is, is it worth 40?
/ Central Torque Wrench #2
If it is a click type torque wrench it probably is a good buy. I would rather pay about $25 for something such as that because you don't know how exact it is going to be, but for the average personal use, it shouldn't matter if it is off a few pounds of adjustment. Give $25 a try and see if they bite. You have nothing to loose. I think that a new one at Sears is about $100 and they guaranty them for 90 days for accuracy. Guess that they know how well they are made.
/ Central Torque Wrench #3
Is Central a Harbor Freight brand? They currently have a 1/2" clicker wrench for $9.99 under the Pittsburg name.
See if there is a country of orgin on it, Harbor Freight has a lot of Chinese stuff.
Junkman
Yes, it's the clicker type. I went back the other day and gave it a real good looking over and it looks brand new (except for a little grease on the handle. I talked him down to 35. Also found a place on the net that will recalibrate it for 17.50.
shvl73
It's made by Central that make a lot of precision tools. It's also Made in the USA.
Thanks guys
Specs seem the same but the adjustment is different. This one has a locking collar above the handle that you slide down, then twist the handle to the setting you need.
The closest one I could find was the 97353 (mine is 96353), which sounds like the newer model. It sells for 160.
Anyway, I bought it. Whether it was worth it or not, it's mine now /forums/images/graemlins/crazy.gif
/ Central Torque Wrench #7
That seems like a pretty nice deal for a USA made tool.
/ Central Torque Wrench #8
If the 97 series is a newer model and $160, you may have done real good in buying that one.
/ Central Torque Wrench #9
Please tell me where to get it calibrated for $17.50. I have a older (1960's) Craftsman that came with a lifetime warranty that is out of adjustment and they won't do anything for me except to replace it with a cheap beam type unit. Said that they no longer offer a lifetime warranty on the torque wrenches except for the beam units. I will no longer purchase any Craftsman (I now refer to as Crapsman) tools because of this "policy change". I believe that if it came with a lifetime warranty, that they should continue to honor it. Getting back to the original question... where can I find this company to do the re calibration?? thanks
Junkman
This is what I'm going by. I haven't check into it myself so I really don't know.
Read this
/ Central Torque Wrench #11
</font><font color="blue" class="small">( I have a older (1960's) Craftsman that came with a lifetime warranty that is out of adjustment and they won't do anything for me)</font>
I guess they said "It died." <Grinning, ducking & running>
Sears is about the crookedest merchant in the US.
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
2008 CARRIAGE CAMEO 5TH WHEEL CAMPER TRAILER (A63569)
2008 CARRIAGE...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
