5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,852
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
It's dual duel not duel. Duel is 2 people harming each other over some imagined issue.....lolI have a Central Boiler duel fuel outside wood burner which I have had for 15 + years. I would not recommend putting it in an enclosed area like a garage. I have mine under a roof where I keep it and the firewood. It does let out smoke when you open the door to fill it, not all the time but quite often. If you are planning on using an existing chimney it probably will not work that well as the chimney needs to be a certain size to work well. I don't believe you can buy the duel fuel new anymore at least here in Pa. I use the natural gas to start the wood sometimes and use the gas to heat if the wood supply gets low, both heat the house well. We have radiant floor hear and cast iron hot water baseboard in the house, very nice even heat.
Reminds me of the often ill used word 'defence', it's 'defense' not defence according to Webster's unabridged dictionary
