Toplink CCM Hydraulic TopLinks have arrived!
   / CCM Hydraulic TopLinks have arrived! #1
HayDR
Veteran Member, Approved Advertiser
Johnson City, TN
JD 2040,2240, 2355, 2755, 4055
Implement end CAT 1 & 2, Tractor end CAT 1 with the double piloted check valve
19" to 27"
Thank You for your patience
Mark Carter
   / CCM Hydraulic TopLinks have arrived! #2
I need some help filling out your Custom Fit questions on your website.
I have a 2005 KAMA 554 tractor, are you familiar with that model? I don't know if it has a closed or open center on its hydraulic system. I do know there are two levers that operate the hydraulic ports to the rear. It has two exterior sets in the rear.
I am attaching a picture of the rear end where you can see the connections, the top and side links too. Please send me a PM because I want to purchase a complete system from you. I want to make sure it will fit and work properly.
   / CCM Hydraulic TopLinks have arrived! #3
</font><font color="blue" class="small">( I need some help filling out your Custom Fit questions on your website. Please send me a PM because I want to purchase a complete system from you. I want to make sure it will fit and work properly. )</font>
Attached is another photo of the side links on the tractor.
   / CCM Hydraulic TopLinks have arrived! #4
Since you already have 2 rear remotes all you would need is a top link cylinder and a side/tilt link cylinder and corresponding hoses and fittings. You do not need any additional valves. Just measure your top and side links for max and min extensions and order the appropriate cylinders from CCM.
   / CCM Hydraulic TopLinks have arrived! #5
Big Brown Goodie truck just dropped mine off from C&CM. Will have to wait till wed to put it on. Side link next year- I hope.
To quote an old Bartles and James line " Thank you for your support."
Mark Carter
   / CCM Hydraulic TopLinks have arrived! #7
I mounted mine Thursday night. The cat2 end was too wide for my quick hitch so I used a cutting disc on my angle grinder to trim the ears off of the ball socket and it works great! I took some pics this a.m.
   / CCM Hydraulic TopLinks have arrived! #8
More photos in the tractor album from the link in my sig.
   / CCM Hydraulic TopLinks have arrived! #9
)</font>
Made in Turkey?
Made in Spain.
We have missed you Erol where have you been?
2014 PETERBILT 388 (A55745)
2014 PETERBILT 388...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
