CC-Y SC2400
   / CC-Y SC2400 #1
peterg333
Looking!
I am looking to purchase a new sc2400. I will use it to take care of 5 acres for mostly snow moving and "conditioning" a horse riding arena with a harrow. My harrow is 673 pounds...max. 3 pt hitch weight on sc2400 is 661. Will this be a problem? Can I still use this harrow? If I do...will I potentially be causing any problems??? Thanks!
   / CC-Y SC2400 #2
I think your really going to have a hard time pulling that harrow if at all in an arena.
Buck
   / CC-Y SC2400
The harrow...it seems..is "only" 620 lbs. But...why do you think that I'll have a hard trime pulling the harrow in the arena?
   / CC-Y SC2400 #4
There are many different kinds of harrows but we have two different styles in the weight range and both take a tractor with about twice the horsepower and more than twice the weight and even that will feel underpowered. Any chance you could show a pic of the harrow?
Buck
   / CC-Y SC2400
Its a redmaster harrow. Specs say that it needs 22 HP. I have been using a New Holland 7308 and it works just fine! The sc2400 is 24 HP...sooo...I thought that the hp wouldn't be a problem! red_master_harrow.jpg
   / CC-Y SC2400 #6
The 7308 is the loader and it is typically used on a TC-30 tractor which is a compact tractor. The SC2400 is a sub compact tractor. A comparable tractor in Cub, to the TC-30 would be the EX3200. Implement manufactures confuse the issue when they use horsepower as a "size". Are they talking about a Ford 8n at 22 horsepower or a sub compact SC2400 that is 4 times smaller. Looking at the harrow on their web site I think it is way too much for the SC2400
   / CC-Y SC2400
Thank you very much for your replies! I will try the harrow with the sc2400 before I buy. Is there anything that I should "look out for" when trying the 2400 with the harrow? Run in 4wd? What if I were to "swap" my 8' harrow for the 6' model (about 100lbs lighter)....? Thanks!
   / CC-Y SC2400 #8
I almost hate to even say anything on this thread but I have been really impressed with my sc2400 as far as pulling power. I do very little ground engagment with it other than the box blade But I will say it pulls that very well a 5' box blade if fact I believe it does a better job than the old ford does those front wheels driving make a heck of a difference. That being said I do know front wheel drive is a costly thing to fix and the more you use it the more it breaks
But I vote for trying it after all your not breaking sod with it see what it does and knocking it down to 6' will make a lot of difference
   / CC-Y SC2400 #9
Did you get it ?
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
UNUSED TOPCAT SSSG72 HYD QUICK ATTACH GRADER BLADE (A51244)
UNUSED TOPCAT...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
