CC SC2400 Hydraulic Quick Connects
   / CC SC2400 Hydraulic Quick Connects #1
dwebb
Lucas, Texas
John Deere 1025R
I have a 2011 CC SC2400 and I am having trouble getting the quick connect couplings to stop leaking. These are the couplings that connect the hydraulic lines to the FEL. I would like to switch them out for some better couplings but I can't find anyone that knows the specs on the couplings so that I can make sure I have a match.
Can anyone provide the specs for these couplings (flow rate, pressure rating, etc.) or maybe make a suggestion for replacement couplings that won't leak as much? Any information would be appreciated.
   / CC SC2400 Hydraulic Quick Connects #2
Have you tried replacing the o-rings inside the female portion of the quick-disconnect? I think the o-ring replacements would be available at any good hyd supply company.
No, I have not tried that. I already replaced one after it was brand new because of leaks. And, as little as these couplings have been used (less than a dozen times), I'm beginning to think that these are just sub-par couplings. They leak straight down on top of the MMM and create a mess that I constantly have to clean up. I have researched couplings on the internet but I can't be sure if I'm getting a match. I have no numbers to go by. One hydraulic supply company I called said the couplings are matched to the overall capacity, pressure, and flow of the entire system, pumps and hoses. I had no idea that hydraulic systems were that complicated. I had no idea it would be this hard to figure out something that appears to be so simple on the surface.
   / CC SC2400 Hydraulic Quick Connects #4
I think most tractor hyd pumps don't put out more flow than the lowest spec'd couplings can handle. I looked unsuccessfully on CC parts for the couplers.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2017 PETERBILT 567 (A52472)
2017 PETERBILT 567...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
