CC 3200 deck stop/lift linkage and grease fittings
   / CC 3200 deck stop/lift linkage and grease fittings #1
scottd
South Hero Vermont
I have 11 hours on my new 3200 and love it. The 54 inch heavy duty deck is indeed heavy. I took it off and greased it. I found that 2 of the press in grease fittings fell off. One on a spindle and one on the inner front wheel. From what I have been reading I guess I have to tap and screw a new grease fitting in each. I guess I am fixing to learn how to do that. Any ideas on the tools I need and tips? I also seem to have an issue with the mechanism of the deck stop/lift linkage. It has always seemed to make a "that sounds bad" sound as it seats when it's in the down position and It appeared that the one inch snap ring was not on from the factory as I found the washer on the deck and no snap ring. I replaced the washer and one inch snap ring and now both the snap ring and washer are on my lawn somewhere. I looked under at the center hydraulic lift linkage and I think something is not right. Has anyone had this issue or any ideas as to what is going on?. Before I ball out my dealer I want to have an understanding of the problem. The dealer thought that the snap ring was not on correctly but I now believe there is something a miss with the lift linkage.
--scottd
--scottd
New/Unused 2025 H12R Mini Excavator (A51573)
New/Unused 2025...
UNUSED GOLD MOUNTAIN M202010 20'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
Electric Concrete Mixer (A51573)
Electric Concrete...
2011 Liebherr L586 (A53472)
2011 Liebherr L586...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
Kubota ZG327 (A50120)
