CC 2518 stalling problem
   / CC 2518 stalling problem #1
drifter2518
Central NY
MF GC2400 that replaced retired CC 2518 and retired CC 2160
I've got a CC 2518 that I just replaced the battery last month because it was 3 years old. Today while mowing for a hour the tractor just quit. I checked the volts with a meter when it stopped and it started at 9.9 and kept climbing to 11.90. I hooked up my fast charger to the tractor and it started so I drove it back to the shed and put the slow charger on it. My question is how do I check to see if it's charging on it's own to see if it's just a bad battery? Thanks for your answers.
   / CC 2518 stalling problem #2
several things to chk:
1) make sure your battery's polarity is correct and that lug and ground connections have been cleaned with sandpaper to a clean finish.
2) Remove battery - take to qualified shop for a LOAD test.
3) with know good charged battery hooked up, post terminal voltage at rest (no load) s/b >12 - 12.5 volts DC. With engine runnig at full throttle, s/b >13.2 volts at batt posts. If less, then time to get help with troubleshooting your tractor's charging circuit (post back here).
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
