Cb radio mounted on 4 wheeler
   / Cb radio mounted on 4 wheeler #1
BigP9540
Charlottesville,Virginia
Kubota m9540 kubota 5030 kubota 4330 tlb John Deere 955
Mounted a cb radio to the Atv last week started by welding a squarish price of steel to the back rack for antenna magnet mount then drilled holes on top of left front fender for radio mount wired it up and turned out great
   / Cb radio mounted on 4 wheeler #2
That looks like a pretty nice radio you have there ! Looks like from pic from afar it has a built in swr meter.
Did you check your swr's ? If not sooner or later you will fry your transmit final in your radio.
Also just cause you hear everyone does not mean they will hear you. Its difficult to mount a cb on an atv and get out far.
Not to much what we call ground plane. A 9' steel whip will get out better but once again swr's must be checked.
Not trying to be a hard arse or want to come across as an know it all but don't wanna see your damage your radio.
Wish Ya Well !
Boone
   / Cb radio mounted on 4 wheeler #3
Dont forget and leave taht thing on! those batteries are tiny and probly not much reserve in them!!!!!
   / Cb radio mounted on 4 wheeler #4
You could wire in a relay so the radio power cuts off with the ignition.
   / Cb radio mounted on 4 wheeler #5
Sweet Recon!When you get all finished with it could you post a drawing of how to fabricate one for mine?
   / Cb radio mounted on 4 wheeler #6
All he did is weld flat steel into the back rack? Looks like he just drilled the radio to the fender with the same bracket you hang it in a truck?
It is a cool recon. I like the older hondas, reliable and fuel efficient. The new 4 wheels are almost 2 big to get through the wooods. Also who needs to sit that high and go 60mph?
I have an 89 4trx 300
2015 GMC Yukon XL Denali SUV (A50324)
2015 GMC Yukon XL...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2000 Genie S-60 60ft Telescoping Boom Lift (A50322)
2000 Genie S-60...
New Holland 276 Square Baler (A50774)
New Holland 276...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2018 JCB 507-42 7,000LB Telehandler (A50322)
2018 JCB 507-42...
