CAV spring position maybe wrong
   / CAV spring position maybe wrong #1
Jipp
mf35 3cyl diesel
Recently i cleaned my CAV injection pump because everything was stuck. After this starting was difficult and the throttle at idle speed was no longer in its original position. What did i do wrong? Used govenor spring code number 3, is this correct?
The older pump has the following numbers: CAV dpa 3232038 serial number R9518 ZA
   / CAV spring position maybe wrong #2
Welcome to TBN!
Did get the right number for the code?
Center hole pn both ends tends to be common, not saying this is the case pn yours. Spring wear on holes on this old a tractor is usually apparent.
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2000 Freightliner FLD112 Truck, VIN # 1FUY3MDB4YDF65459 (A48836)
2000 Freightliner...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A50397)
2022 Down2Earth...
2004 Ford F-750 Crew Cab Wrecker Tow Truck (A48081)
2004 Ford F-750...
2022 CATERPILLAR 299D3 XE SKID STEER (A50458)
2022 CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
