Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor
   / Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor #11
Glad things worked out ok ! I too keep 2 extingueshers on different end of my garage. Going to make it one of my priorities to attach FE on my tractor ASAP (Brian method). Thanks to all for reminder (cheap insurance).
Boone
   / Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor #12
   / Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor #13
Nicely done, Brian.
You even got the paint to match!
   / Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor #14
Talk about enough extinguishers, I have 9 in my 2 story garage. 3 co2 and 6 powder. One each in the two vehicles and boat but none on the tractor (I'll have to remedy that). Also have 8 of them in the house at various locations, Halon, co2, and powder. We have a volunteer fire department here, and you are the best first responder. By the time they assemble and get on scene, their considered foundation savers.
   / Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor #15
Really glad to hear that since you were home and near a fire extinguisher things turned out okay. I think of fire extinguishers as cheap insurance policies, you get them and hope you never need them. I have them all over the place, and one with each vehicle, but here's another thought - it's important to check their gauges and replace or recharge if necessary. Example: I put a fire extinguisher on the tractor's roll bar years ago. One time while bushogging I backed under a low branch and the extinguisher got set off for a short burst. That was a surprise! The gauge now reads a little low. They say that setting them off even once breaks the seal, allowing them to leak down. The point is, this story gives me the incentive to replace that little sucker before I actually need it. I also read that the constant vibration of being on the tractor can compact the contents of the extinguisher to the point where it might not work. Don't know if that's true or not, but I figure why take a chance. I'm putting this on the top of my to-do list.
That is very true!! This is why you frequently need to take the dry chemical extinguishers out of their bracket, turn it upside down, and shake it until you can feel the chemical moving around inside it. On mine, it seems like the longer I let it compact, the harder it will be to break it up. I learned that right here on TBN. :thumbsup:
   / Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor #16
Don't forget too, that in a case like this, you CAN put out a grease fire with SNOW, rather than running to the house/garage. Doesn't help on a hay rig though.
   / Cautionary tale. Check your Shear Bolts and get a fire extinguisher for your tractor #17
i carry a FE on all my tractors. good insurance.
on the yoke ont he tractor.. if it is siezed.. I suggest carefully attacking it with a die grinder till you can split it and then use a chissle to driv eit open a hair then slide off.
Sometimes my drivelines heat up when under a load, like the round baler, and that heavy shaft gets stuck on there. A little squirt of kroil, and just a little bit of persuasion with a pry bar and it's off. Hopefully yours is that simple.
Tried again today with no luck. I'll try to figure out what kroil is. I haven't tried fluid film yet.
I found out that the heat from the fire was so much that it slightly melted a portion of the drawbar which the spinning shaft was able to get close to.! Not enough to have to replace it but I will have to grind it down a bit to smooth it out.
I actually tried that for a little bit. Didn't seem to be working. Decided it wasn't worth messing around with since I had a FE not far away.
I was hoping I wouldn't have to but it seems I might.
What about just heating it up a bit and trying to use a crowbar to get it off?
Annoying thing is I can't even get it to move a bit to a position where the lock that holds it on will stay undone.
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
Husky Aluminum Truckbed Toolbox 21" x 70" - Diamond Plate (A59225)
Husky Aluminum...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
flooring (A55758)
flooring (A55758)
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
Quick Coupler Plate Loader Attachment (A56857)
Quick Coupler...
