Cause of 2538 increased idle RPMs to 3000?
   / Cause of 2538 increased idle RPMs to 3000? #1
qwikstart
reno, NV
mahindra 2538
Started engine - rpms at 3000 and not decreasing after suggestions to remedy....battery ok.
Does anyone know what might cause rpms to increase at idle?
I would appreciate any suggestion or advice before last ditch option - hauling in to dealer.
Thanks, Deb
   / Cause of 2538 increased idle RPMs to 3000? #2
Could be your throttle cable has slipped, or gotten stuck.
Check on the left side of the engine, about 1/3 of the way in front of the firewall. You'll see the cable attached to a black plastic arm, that pivots sideways. That's the throttle control. I happened to check mine yesterday, and didn't see (wasn't looking hard) an idle adjustment screw. That's why I suggested to check the stop on the cable. Maybe check where the cable goes thru the firewall as well.
Sorry I couldn't be of more help. I'm sure several of the guys on here will have better ideas for you.
Keep us posted.
Keep us posted.
Thanks for your suggestion!
The thing I didn't mention was that the engine was not functioning as if the "rpm's" were that high - I figure it should be screaming. Yes?
As this is all new to me, I was hesitant to assume that maybe the tachometer needle was off or something similar.
But, after checking through possibilities, I called the dealer.
Result: I am the 4th owner of Mahindra 2538 in my area to report similarly. Tachometer reading affected. Instrument panel needs replacing - under warranty.
Thanks again.
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
2015 FORD E-350 14 PASSENGER VAN (A52472)
2015 FORD E-350 14...
Informational Lot - Financing (A53473)
Informational Lot...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
