Caterpillar warranty
   / Caterpillar warranty #1
brain55
Brentwood, CA
I have a customer with a 259B compact track loader. He was complaining about lack of hydraulic lift power and the boom drifting down. I checked it out and determined that the LH boom cylinder was leaking fluid past the piston seal. Though the machine is under warranty he felt is was less hassle and more cost effective for me to put a new seal kit in it. So I pulled the cylinder off and disassembled it, sure enough the piston seal was shot. It looked to me like something else had come apart in the hydraulic system. There was a bunch of metal embedded in the seals, wear rings, and piston.
I called the closest Cat dealer and was told it had to go to the selling dealer and apparently for every machine sold a certain amount of money is put in a warranty account for that dealer. So my customer hauled the machine to the selling dealer 50 miles away. I may not work on a lot of Cat equipment but I'm sure I've repaired a couple hundred hydraulic cylinders in my 25+ years as an equipment mechanic so I'm pretty confident in my abilities to repair and diagnose them. The dealer is trying to tell him that the rod is bent and the metal was from the piston. I've seen plenty of bent rods and I have never seen one tear up a piston and cylinder like this, not to mention bent rods tend to show signs of wear in the gland and on the rod. I wish I had pictures. Anybody with any experience at all would come to the same conclusion I did. It sucks that Cat won't stand behind their equipment and wants to charge him $5000 for the repair.
I'm sure their lack of desire to make any warranty concessions is due to their warranty system. The more they keep in their warranty account the better off they are. When I was working as a Kubota dealer mechanic I wrote plenty of warranty claims I was good at it too. I don't get their policy. I'm going with my customer in the morning to have Cat show us where this rod is bent and explain how it is my customer's fault.
The reality is he won't buy another piece of Cat equipment.
   / Caterpillar warranty #2
I have tons and tons of CAT equipment and engines.
I've never had a single warranty issue. Its broken, under warranty, they fix it. End.
I've also never heard of that way they do warranty... CAT is CAT. Unless it's a specialty bid item. A customer of mine bought a few D11's specially outfitted for them. Only Ohio CAT can/will service them.
Okay, went and looked at the cylinder this morning. There was a ding in the tube that I missed. It had been there for awhile no wonder there was so much metal in the cylinder. So both cylinders need to be replaced along with the control valve. The spool is stuck in the valve body now. The $5000 repair bill seems a lot more reasonable. I'm glad we went and looked at it. My customer is satisfied though he's walking a little funny lol.
Brian
   / Caterpillar warranty #4
It takes a very good Mechanic to come back here and admit he missed something. That's how we learn.
1999 Honda VT1100C Motorcycle (A51694)
1999 Honda VT1100C...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
1840 (A51248)
1840 (A51248)
Yerf-Dog Go Kart (A53117)
Yerf-Dog Go Kart...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
