Category 3 / PTO
   / Category 3 / PTO #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Power Take Offs (PTOs) to operate Category 1 and Category 2 size implements are the same.
What about Category 3 PTOs?
~~~same size?
~~~same operating RPM? (540 RPM)
I should know this, but I do not.
Thanks.....
   / Category 3 / PTO #2
pto speed and size offerings are more along the lines of tractor hp abilities and imp needs. 540 will always be the same 1.375 x 6 splines and is typically only used in lower hp instances. The next step up in hp requirements goes to small 1000 which will always be 1.375 x 21 spline. After that then it goes to large 1000 and it will always be 1.75 x 20 splines. Cat III tractors can be either small 1000 or large 1000 as well as the implements but probably leans to the small 1000 side as cat III is not a terribly large offering in the ag world. Once you get into cat IV, etc then we start to see just large 1000 or no pto/three point at all.
   / Category 3 / PTO
Thank you. THANK YOU.
   / Category 3 / PTO #4
Cat 3 does not mean only 1000 rpm. Our 7720 Deere is Cat 3 and is either 1000 or 540, I believe by changing the drive shaft - the 1000 rpm shaft meshes with a different set of drive gears than the 540. Ours is only used on our 540 rpm baler so I don't know about changing it. Our Cat 2 M135GX Kubota is used on either a 1,000 rpm chopper or its 540 rpm backup so the tractor PTO output shafts get switched when necessary. The 540 chopper has a notice that the driveline is limited to 90 PTO HP so we need to run slower when using the backup chopper.
   / Category 3 / PTO
Thank you, MHARRYE.
   / Category 3 / PTO #6
And thanks to everyone... Once again I've learnt something today on TBN.
Yay!!! :thumbsup:
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2020 JOHN DEERE 7R210 LOT NUMBER 50 (A53084)
2020 JOHN DEERE...
2012 Mack CXU613 Sleeper Truck, VIN # 1M1AW07Y3CM018973 (A51572)
2012 Mack CXU613...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
