Category 2 implement on a category 1 tractor
   / Category 2 implement on a category 1 tractor #1
RunningSpring
Kubota B7100
Gentlemen,
I'm looking to purchase the cp560 (rotary brush cutter) from Baumalight. I want to run it on my families Massey Ferguson 245 which has a category 1 type hitch. The implement is category 2. I have attached (or tried to) the spec sheet from Baumalight. My question is this: It looks like all I would need to do is just put in category 1 pins with maybe a bushing. Is it that simple? I should have plenty of spread on my lift arms. Thanks again guys. Just need some advice before I make a big (for me) purchase
  • CP560.pdf
   / Category 2 implement on a category 1 tractor #3
Nice looking cutter! The hitches have a different geometry so you might have weird angles mixing the two. The top link are different heights relative to the lift arms: Three-point hitch - Wikipedia
Since that cutter is cat 2 it might be a little heavy for your tractor - and the Cat 1 hitch. Your horsepower is sufficient (minimum) but the front end might be a little light. I think I would recommend getting a lighter bushhog.
   / Category 2 implement on a category 1 tractor #4
They recommend 40 to 65 HP tractor so you should be okay although a little light for what the cutter is shown capable of - if the arms fit. Hitch categories are per a SAE standard - Cat 1 up to 45 HP, Cat 2 40 to 100. Kubota Grand L's, for example, have the L4560 with Cat 1 and L5060 with Cat 1-2. I have a L6060 with the Cat 1-2. The mounting points are sized for Cat 2 so to use a Cat 1 I need to sleeve or switch the pins on the implement to Cat 2 (if possible). So if the cutter is Cat 2, the pins are larger than the spherical bushings in your lift arms so its not possible to sleeve. If you put smaller pins in the cutter holes (as the pins shown in the illustration), they will be really sloppy. Dimensions look like a perfect fit for Cat 1 except for pin diameter which isn't shown on the illustration.
   / Category 2 implement on a category 1 tractor #5
The weight of that tractor is around 4K so it probably will be fine. It may get light up front, but I guess you can fix that with some suitcase weights if it is an issue. I presume you are buying such a HD cutter because you have some pretty gnarly stuff you want to cut. You are on the bottom end of the HP range though which may mean you can't get the best out of the machine. Your gearbox is super safe, but make sure you aren't buying a Ferrari to drive in a school zone. I had a cutter too big and had to drive so slow to compensate it drove me crazy.
Thanks for the replies. I do have heavy suitcase weights up front so I think I'm fine on the weight. In terms of the horsepower, I do appreciate I'm at the bottom end of the recommended range. I do have a heavy brush hog already and it's just not quite up to what I'd like to do. I'm trying to clear an overgrown field (mostly coyote brush) and it's just to heavy to do with my brush hog. This machine seemed good because with the open back I thought I could get to the brush without having to drive over it.
In terms of making the pins fit; is there a bushing that goes in the holes of the attachment to reduce the slop? Or is there another way I could make it fit? I'm not totally sold on this particular attachment but I am looking for some piece of heavy equipment to clear this area.
   / Category 2 implement on a category 1 tractor #7
Get yourself a Brown Tree Cutter!
   / Category 2 implement on a category 1 tractor #8
Yes, get two Cat2 to Cat1 Pins. The thread diameter is 1-1/8", the pin is 7/8":
   / Category 2 implement on a category 1 tractor #9
Honestly - I think I would want a heavier tractor. It might just be like the tail wagging the dog here. JMHO
   / Category 2 implement on a category 1 tractor #10
This project sounds like grinding off brush and leaving fuzzy stumps everywhere. Since we now know you already have a bush hog, perhaps you would do better with another implement that helps you pull out the brush - stump and all. Make a burn pile and you will be better off in the long run.
Not sure if you have a loader, but there should be a 3pt attachment that allows you to grip the base of the brush and lift - push - pull and rip it out.
Google '3pt tree puller'.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
