Cat247b battery light stays on
/ Cat247b battery light stays on #1
Garyinca
Laytonville ca
247b
247b battery light stayed on . Volt meter to batt not runnging 12v started increase 13v
/ Cat247b battery light stays on #2
not sure about specific unit you have.
if it is a 12v battery, and you put a multi meter across the pos and neg posts. a good battery should read above 12v. say 12.4v
when unit is on and running, and the altenator is charging battery, you should get 14v or a little higher say 14.4v
you can take battery out, and most automotive part stores, should be able to do a "load test" on battery as well to see if it can put out the cranking amps (CA)
double check battery also has water in it, if it is old style batteries and not the newer solid state battery.
It turned out to be bad alternater batterylight is volt meter
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
Columbia Vise (A65640)
2020 International LT625 48" Sleeper (A62613)
2020 International...
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
