Cat skid steer starter relay
   / Cat skid steer starter relay #1
rlinhart
I have a Cat 236 that won't turn over. Battery tested ok, cables and contacts are all good and the starter tests ok when jumped across the solenoid. The wire from the keyswitch to the starter will not energize when the switch is turned, so it seems that the keyswitch must be bad OR is there a relay between the keyswitch and the starter?
Thanks,
Rich
   / Cat skid steer starter relay #2
Rich did you check the lap bar switch? Are all the hydraulics "off"? Just a few things to look at. Hope this helps.
Thanks, I did not think of a potential safety switch problem.
Well, that was it. Some vandal unplugged the lap bar safety switch. Thanks for your help! Rich
   / Cat skid steer starter relay #5
Glad to help! I've experienced the same thing myself! but never a switch going bad. Welcome to the board. We all learn from everyones input. Post back often!
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2017 Ford F-350 Ext. Cab Pickup Truck (A49461)
2017 Ford F-350...
2020 John Deere 6110M 110HP 4WD Agricultural Tractor (A49461)
2020 John Deere...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2005 John Deere 824J Articulated Wheel Loader (A49461)
2005 John Deere...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
