CAT dipstick states "DO NOT OVERFILL". Why?
/ CAT dipstick states "DO NOT OVERFILL". Why? #1
stoneseeds
Nova Scotia
Cat
CAT 3304 Engine dipstick states: "DO NOT OVERFILL". Why? What could happen?
/ CAT dipstick states "DO NOT OVERFILL". Why? #2
It could conceivably cause abnormal oil consumption,
but mainly, I think, it can cause oil seals to fail.
/ CAT dipstick states "DO NOT OVERFILL". Why? #3
To much oil is bad -just the same as to little the machine can really whip that oil up resulting in foaming which can result in lost cooling, more pressure, drain holes that do not drain back and other problems. When you check the oil you will not be able to tell if is overfull of fuel ,water,or oil.
/ CAT dipstick states "DO NOT OVERFILL". Why? #4
Dad once forgot to drain the old oil from our HS principal's car. He put new oil in it and obviously did not check the dipstick. The principal took the car and soon returned it with the engine's hydraulic valves hammering away. The crankshaft obviously beat the high oil level into a foam. The foam went to the hydraulic lifters and caused them to hammer.
I'd get a similar hammer on my VW Cabrio's hydraulic lifters if I didn't use 5wxx or 0wxx oil. Any heavier oil (at startup) would not get to the lifters quickly enough.
Ralph
/ CAT dipstick states "DO NOT OVERFILL". Why? #5
Crankshaft and rods are not supposed to be submersed in oil. Ever figure the pumping losses?
That is why racers run a deep sump oil pan or a dry sump oiling system. Power is lost and waste heat generated when moving parts slam into oil.
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
2002 LEEBOY paver (A64553)
2002 LEEBOY paver...
2017 Autocar Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A64556)
2017 Autocar...
2016 Ford F-450 Ambulance (A64556)
2016 Ford F-450...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
