CAT D3G; Access leaking Hydraulic Line
/ CAT D3G; Access leaking Hydraulic Line #1
TheRetiredBear
2008 Mahindra 3510, 2006 CAT D3G Dozer, Wood Mizer LX 25 Sawmill
I have a leaking Hyd Line on the right side alone the frame (inside the Eng Compt). I found it when I removed the right Engine Access Panel.
The only way I know to get to the line, is to drop the Belly Pan. I need some advice on the best and/or easiest way to drop and support the belly pan?
Or have any of you come up with another way.
Any help would be much appreciated!
Respectfully
