cat backhoe 1998 416c
/ cat backhoe 1998 416c #1
spo307
Levittown & Long Eddy NY
kubota L4400
the plate says make in england, is it bad to buy a machine made in england, the parts should be the same as us yes? thanks, I know this is for tractors, but I know some guys own b/h, thanks
/ cat backhoe 1998 416c #2
Some out there may own tractors made in England. My own Ferguson TE (the E stands for England I'm told) -20 was made in england. It is around a '52 vintage so some of the threads on the steering are weird for us.
/ cat backhoe 1998 416c #3
Parts for Cat machines are usually very easy to get. IMO, the 416C has too short of a wheelbase and gets stuck pretty easily.
/ cat backhoe 1998 416c #4
I think what you're asking is if there's a problem buying a machine made in England. I would answer that with "no". England makes a lot of tractors & machines. TEREX backhoes are also made in England. So were FERMEC backhoes. My old Ford backhoe was made in Belgium.
I have never seen an American made CAT backhoe. Every one I've seen is made overseas. In the last 20 years, the only American made backhoes I know of are CASE and John Deere.
I have worked in Manhattan for a couple years,most of the construction companys I have worked for all had cats and I cant remember not seeing a usa ill. plate on the machines. thanks for the replys
/ cat backhoe 1998 416c #6
Most of the cat dozers are made in Mexico now. I think they only make the D6E in their plant in ILL. Most of the heavy equipment is made somewhere besides US. Ditch Witch is the exeception that I know of off the top of my head. The Cat hoes are good machines, alot of power and very big cab.
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
iDrive TDS-2010H...
(INOP) 2018 JOHN DEERE 50G EXCAVATOR (A62129)
(INOP) 2018 JOHN...
2019 John Deere R-4038 (A63118)
2019 John Deere...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
