Cat 953 LGP For Driveway Work
   / Cat 953 LGP For Driveway Work #1
SnowRidge
Elite Member
East Tennessee
Power Trac PT-425 / Branson 3520
I am about to put in the driveway at our new place. A fellow with a Cat 953 LGP was recommended. He gets $100 an hour and $150 transport fee. I like the guy and have watched him work for a neighbor. He doesn't take breaks or mess around. He just works. The neighbor was not there to keep an eye on him or anything like that.
The driveway will be roughly 700 feet long, require a lot of fill in one very low spot, and have three stream crossings, two of which are minor wet weather streams. It is all rolling woods, with side cuts necessary at the entry point in order to keep it from being too steep. Power will go down the drive. The utility requires a 30 foot cleared path.
The dozer owner suggests getting the fill off of the property rather than buying dirt and trucking it in. He has suggested three 3 foot diameter culverts, which I will have to purchase and have delivered or haul myself to the site.
He has a buddy that hauls rock for a living. He would use him to get the gravel from the nearest local source. He suggests 1 1/4" rock. He says he can compact the fill with the Cat and a roller would not be necessary, although one could be used, if I wanted to rent one.
He will clear the drive/power area by pushing the trees down. They will be shoved to the side. He said he could move them to a burn pile, but said the costs would be higher.
I was originally thinking of contracting the driveway's construction. This avenue is more like a cooperative effort with him doing the heavy work with his machine. It seems like this would be a cheaper approach than a contract.
Does the price sound fair, and is the Cat 953 LGP a good machine for this kind of work? All comments or questions are welcome.
Thanks,
SnowRidge
   / Cat 953 LGP For Driveway Work #2
The CAT 953 LGP is a big machine. Probably more than suitable for this kind of work, depending on the size of the trees to be moved.
Did he give you an estimate on how long it would take?
He said he figured three full days at 8-10 hours a day.
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
1980 PULLMAN DRYVAN (A50854)
1980 PULLMAN...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2014 CHEVROLET SILVERADO (A50854)
2014 CHEVROLET...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
Knapheide Service Body with Liftgate (A49461)
Knapheide Service...
