Cat 287B hyd line question?
/ Cat 287B hyd line question? #1
dirtworksequip
Veteran Member
Wheeling, WV
2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
Anyone know how I can keep from loosing all the hyd fluid in the tank while replacing a non pressurized line? Can't kink it because of wire inside.Open to any suggestions.
/ Cat 287B hyd line question? #2
By non-pressurized line do you mean the suction line that goes from the tank to the pump? If so then you are probably out of luck especially if the tank is higher than the line you are replacing as there is no easy way from stopping fluid from flowing down. Gravity can be a pain you know.
I had to drain the tank in my dozer to replace the rubber hose part of the suction line because the tank is high behind the seat and the pump was almost below the engine. The rubber suction hose connected the hard metal line from the tank to another hard line to the pump. The wire in the 1.5" ID suction hose is pretty heavy and does not bend very easily.
/ Cat 287B hyd line question? #3
You could pump it out into a clean container. Then service the hose and refill the tank.
Eric
Thanks for the suggestions. Yes, that is what I came to the conclusion of doing. I'm going to get a piece of poly hose and hook it to a battery powered kerosene pump and try pumping out most of the oil. It only holds 9.2 gallons.
The other problem is.......... the hose ends are both real tough to get access to. The good part is they are just held in place with hose clamps so I would not have to get a wrench in there, just a screw driver
Once I get the oil out I may just cut the hose and try and find something to slip inside to use as a coupler and put 2 more hose clamps on.
I figure its probably an $80 to $100 hose since its formed.
Thanks again for the replys!
Mad, I always heard "Let gravity be your friend" , but I know what you mean if it is working against you.
/ Cat 287B hyd line question? #6
I have clamped vise grips on lines before to keep oil from draining.
/ Cat 287B hyd line question? #7
But that would be pretty hard on a suction line that is either metal or a 2" OD hose with heavy wire woven into the hose fabric. Suction hose is constructed a lot different than pressure hose.
/ Cat 287B hyd line question? #8
Woven wire is what I have used vise grips on. If the hose is a larger size, you can use welding vise grips. Of course if the hose is to large or to stiff, you can't do it this way.
Opps. I just noticed the size of unit that he is working on in the title. I don't guess the vise grips will work on that size of hoses.
/ Cat 287B hyd line question? #9
Also alot of suction hoses are reinforced with a very heavy gauge wire. If you tried to pinch it shut you would bend the wire and then have a flat spot in your hose that would then cause a restriction.
Pumping out your tank is probably your best bet. Once you do it, if you can I would install a shut off valve. That way if you ever have to do it again you won't have to drain the tank, only turn the valve off to the tank.
/ Cat 287B hyd line question? #10
In some cases you can hook a vacuum hose (from a vacuum pump, running engine, etc.) to tank and it will slow it way down or not let it run out at all. We used to do this on hyd. rigs we used to rent that had 40 gal.+ tanks on them. I don't know how big of an inlet filler you have, or if there is a round plate on tank top you can pull (sometimes to access filter/screen), you might be able to place a ping-pong ball into opening inside tank to block oil from escaping as long as ball is larger than hole going to hose.
The hose that I'm dealing with feels like it has wire spring in it like a radiator hose.
Could not get the hyd. oil pumped out.(too cold) I unclamped the lower end of hose and took my chances that the oil would not come gushing out. It was not too bad. I was able to stuff a rag in it to slow the oil flow. Cut the bad spot out of hose and then slid a 1-1/2 inch copper plumbing coupler inside the hose to use as a stiffner. Put 2 stainless hose clamps on and it should be ready to go after I refill with oil.
Thanks again for all who made suggestions!
/ Cat 287B hyd line question? #13
That is exactly what a suction hose has woven into it.
Splicing it did not work. I'll be going to the Cat dealer tomorrow for the hose. Now I have to figure out how I'm going to bend myself into a pretzel to get the upper end off.
/ Cat 287B hyd line question? #15
Just ask the Cat dealer what they will charge to come change it for you and I'll bet you can figure a way to change it pretty quick.
/ Cat 287B hyd line question? #16
You can hook a shop vac to the hydraulic fill to create a suction/vaccume effect, you'll hardly lose a drop, sounds strange but it works like a charm. I've done it on my excavator and dozer, but not on my 287 yet, it should work though, just try to get a good seal at the fill neck
Getting a CAT mechanic to fix it is out. I would not want to even pay the travel time. I forget what their rate is? That would be a last resort.I have a couple of heavy equipment machanics I know from working different jobs that I could get if I can't get it myself. I just have to give it a long cussing and eventually I get the job done. I was able to access it thru the small belly plate cover. PITA though. I guess anymore anything you have to work on is tough. Auto,tractor or equipment.
Thanks to everyone that gave suggestions.
MMS 800 Remote Control Lawn Mower (A60463)
MMS 800 Remote...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2001 Peterbilt (A60352)
2001 Peterbilt...
2018 MACK PINNACLE (A60736)
2018 MACK PINNACLE...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
