Cat 257B Tracked Skid Steer
   / Cat 257B Tracked Skid Steer #1
MidGALandscaper
Middle GA
JD4310
I have been doing a lot of research on the CAT 257B. I hope to demo one in the next week or so. Basically, I need a loader that can handle full pallets of sod or pavers(sometimes moving them off of a semi-trailer) and do finish grading work (harley rake and 4in1 bucket with toothbar). Can a CAT 257B do this comfortably. I have a JD4720 CAB that stuggles with a pallet of sod.
   / Cat 257B Tracked Skid Steer #2
The 257B will probably be about borderline with pallets and a full pallet. Its tipping capacity is slightly less than that of the T190, and the T190 is all right with a full pallet of sod. That being said, I don't recommend going to the full tipping capacity of the machine. It's rather dangerous to operate that close to the operating envelope.
   / Cat 257B Tracked Skid Steer #3
I have a 257 and it is a excellent machine,I purchased it a little over 3 years ago I have used it to unload a lot of heavy stuf, I have unloaded full pallets of sod with no problem I would put the weight around 2500 lbs. it is stable however you should be very careful keep the load low when traveling and go slow, I would not want to do this on a steady diet. I have an asv rc100 that I now use for the heavy loads. However The Cat is very nimble and it is great doing landscape work I love using it with the Harley rake it does an excellent job. I give the cat better marks in regards to the asv when it comes to quality. I have used the cat to unload full pallets of stones and it comes close to the machine tipping you get the feeling the rear is coming off the ground I understand the stone pallets are around 3000 lbs you are really pushing the machine. Hope this helps
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2020 KUBOTA RTV...
PALLET OF PIPE CLAMPS (A50854)
PALLET OF PIPE...
