Cat 248 Skid Steer Cranking Problem
/ Cat 248 Skid Steer Cranking Problem #1
Mowermoney
Eatonton, Georgia
Cat 248, & Cat268-B
My Cat 248 Shuts off after starting when you release the key ****ch to the "run" position. It will run as long as you hold the key in the "start" position. After several attempts it will finally run. My question is wheather this is a switch problem or a bad fuel shut off solenoid?
Any help would be appreciated.
/ Cat 248 Skid Steer Cranking Problem #2
Sounds like a switch problem to me...Ive witnessed switch concerns on cats...Non like you describe however-let us know what fixes it!
/ Cat 248 Skid Steer Cranking Problem #3
I'd have to agree that it is the ignition switch that is bad. If it were the fuel selenoid it would crank but not run. Since it runs with you holding the key. Bad key switch.
Sincerely, Dirt
I was afraid of that. Switch costs $116.00. The solenoid is less. I still san't understand why it does not malfunction all the time. Someties it goes days without shutting off. Other days I have to crank it 15 or 20 times bebore it will keep running.
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2015 FREIGHTLINER...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2025 MB27 27in Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 MB27 27in...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
300 GALLON PORTABLE FUEL TANK (A64280)
300 GALLON...
159119 (A60430)
159119 (A60430)
