Cat 2 to Cat 1 quick hitch???
   / Cat 2 to Cat 1 quick hitch??? #1
JEBradley
I have a John Deere 4020 which has a category 2 3-point hitch. I have a couple of cat 1 implements, and would like to have the benefit of using a quick coupling adapter, similar to JD's imatch. Are there any of the cat 1 quickhitch adapters out there that will connect to a cat 2 hitch (without modification)?
   / Cat 2 to Cat 1 quick hitch??? #3
There are bushing that you can buy that will adapt 1 to 2 and 2 to 3. However i do not know how well that would work on a quik detach. I would assum that if you put the proper washer on it then is should work just fine. Bear in mind there is a reason for the difference. That is that a cat one is not always built to support the pressure that a cat 2 tractor can exert on it. I have broke implements pulling them on to big a tractor designed for a lesser catagory. /forums/images/graemlins/wink.gif
   / Cat 2 to Cat 1 quick hitch??? #4
   / Cat 2 to Cat 1 quick hitch??? #5
You can replace the pins on the implement with cat two, thats what I did.
   / Cat 2 to Cat 1 quick hitch??? #6
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2015 Frieightliner M2 (A50323)
2015 Frieightliner...
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
Land Honor Skid Steer Double Discharge Concrete Mixer (A50515)
Land Honor Skid...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
