Cat 2 to Cat 1 quick hitch???
   / Cat 2 to Cat 1 quick hitch??? #1
JEBradley
I have a John Deere 4020 which has a category 2 3-point hitch. I have a couple of cat 1 implements, and would like to have the benefit of using a quick coupling adapter, similar to JD's imatch. Are there any of the cat 1 quickhitch adapters out there that will connect to a cat 2 hitch (without modification)?
   / Cat 2 to Cat 1 quick hitch??? #3
There are bushing that you can buy that will adapt 1 to 2 and 2 to 3. However i do not know how well that would work on a quik detach. I would assum that if you put the proper washer on it then is should work just fine. Bear in mind there is a reason for the difference. That is that a cat one is not always built to support the pressure that a cat 2 tractor can exert on it. I have broke implements pulling them on to big a tractor designed for a lesser catagory. /forums/images/graemlins/wink.gif
   / Cat 2 to Cat 1 quick hitch??? #4
   / Cat 2 to Cat 1 quick hitch??? #5
You can replace the pins on the implement with cat two, thats what I did.
   / Cat 2 to Cat 1 quick hitch??? #6
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
200 Gallon 3-point Sprayer 30ft Boom (A52128)
200 Gallon 3-point...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Quick Attach Pallet Forks (A47384)
Quick Attach...
