Cat 1 vs. Cat 0 Lift Heights
   / Cat 1 vs. Cat 0 Lift Heights #1
lpavao
South Carolina
JD X585
With a nex X585 on it's way I'm a little confused regarding all of the talk regarding lift heights on x series 3pt's. How high will the hitch raise vs. the JD2210 or Kubota BX2230?. Also, is it more beneficial to have a Cat 0 installed?.
   / Cat 1 vs. Cat 0 Lift Heights #3
Well- there is a difference. With my tiller on the X585, it would scrape the driveway a bit loading it on the trailer. With the same tiller on the 2210 it clears just fine. The arms on the 2210 are longer giving more lift. Diffinitely go with the Cat 1 which allows you to use many more attachments.
   / Cat 1 vs. Cat 0 Lift Heights #4
Also I have the X585 service manual on disc that I no longer need cause I have the 2210 now. Send me a private email if interested.
   / Cat 1 vs. Cat 0 Lift Heights #5
I have an X595 with a factory 3PH. It is considered a limited Cat 1 and I can lift up a 400 lb ballast box with 8-9" of ground clearance. Check with your dealer because it may not be possible to install a full Cat 1 on your machine. He should also be able to provide you with all the lift specs for the limited CAT 1 hitch on a 585. Cat 0s are very limited, so even if it would fit on your machine, I would stay away from it.
Steve Z
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2013 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER (A54313)
2013 VOLVO VNL64T...
2018 TY-CROP MANUFACTURING LTD DRY BULK PNEUMATIC TRAILER (A53843)
2018 TY-CROP...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55218)
2017 RAM 5500...
