Per Request, I measured my lift arms on my S373D Beaver tractor.
See attached pictures.
Refer to the thrid picture: By loosening up the sway chains (plus bushings to step up from 5/8" pins to 7/8") you can use Cat 0 attactments. The problem is that the where the top link attaches to the tractor is too high, so the top link and bottom arms are not parallel and the attachment does not go up level. I plan to add a third attaching point to the tractor bracket to allow the cat 0 lift link to attach right above the PTO shield. I will need to lengthen my top link as well.
