Cat. 1 Measurements
/ Cat. 1 Measurements #1
robertm
Northern Illinois
Kubota BX2660
Well, after posting questions about ballast boxes, I've decided I may just make one after all, but if not, I will surely make a carryall. So...... that leads me to the question... what are the dimensions (height) for locating the top link attachment point to the ballast? How far above the drawbar pins? Is the top link attached directly above (in line as viewed from the side) the drawbar pins, or slightly before or after? I assume the lower drawbar pins can be spaced according the drawbar I use currently... about 26". Would the same dimensions be used for a carryall?
/ Cat. 1 Measurements #2
You can get basic specs at <A target="_blank" HREF=http://www.speeco.com/3point.html>http://www.speeco.com/3point.html</A>
There is no listing of top link mast height, but I think the Cat 1 is something like 16" above the pin. Your best bet (if you can't find a spec on the web) is to head to the dealership and measure a few similar implements.
Good luck
/ Cat. 1 Measurements #3
Robert, check this thread for your information <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=buildit&Number=124368&fpart=1>3pt Hitch</A>
2016 JLG 800AJ 4x4 80ft Articulating Boom Lift (A61572)
2016 JLG 800AJ 4x4...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2025 44in. Hydraulic Stump Grapple Bucket Mini Skid Steer Attachment (A61572)
2025 44in...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
30" X 12' ADS DRAINAGE PIPE (A64281)
30" X 12' ADS...
