Cat. 1 Measurements
   / Cat. 1 Measurements #1
robertm
Veteran Member
Northern Illinois
Kubota BX2660
Well, after posting questions about ballast boxes, I've decided I may just make one after all, but if not, I will surely make a carryall. So...... that leads me to the question... what are the dimensions (height) for locating the top link attachment point to the ballast? How far above the drawbar pins? Is the top link attached directly above (in line as viewed from the side) the drawbar pins, or slightly before or after? I assume the lower drawbar pins can be spaced according the drawbar I use currently... about 26". Would the same dimensions be used for a carryall?
   / Cat. 1 Measurements #2
You can get basic specs at <A target="_blank" HREF=http://www.speeco.com/3point.html>http://www.speeco.com/3point.html</A>
There is no listing of top link mast height, but I think the Cat 1 is something like 16" above the pin. Your best bet (if you can't find a spec on the web) is to head to the dealership and measure a few similar implements.
Good luck
   / Cat. 1 Measurements #3
Robert, check this thread for your information <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=buildit&Number=124368&fpart=1>3pt Hitch</A>
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
Bud Dry Neon Sign (A50123)
Bud Dry Neon Sign...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
