Cat 1. 3pt quick connect unit.
/ Cat 1. 3pt quick connect unit. #1
NewTexan
Kubota B7500
Has anyone had any experance using one of the many different brands of 3pt quick connect "brackets" that you see at TSC? I kinda like the idea of backing up to an implement, raising the lift up to the pins and flipping two levers to attach the implement. However I haven't heard if they work well or not.
Thanks
/ Cat 1. 3pt quick connect unit. #2
They work well if they fit your attachments.
Problem is many times your implements need to be altered for the quick hitch to fit.
Thanks for the info. I had reason to believe that was the case. I have to move my tension chains quite a bit to switch from the box blade to the brush cutter.
I will just save my money to buy a PHD> /forums/images/graemlins/laugh.gif
/ Cat 1. 3pt quick connect unit. #4
I have one I got at TSC. All the bottom links on my equipment fit fine. I put pins in the top link so I can adjust it quicker. I've been satisified with it.
/ Cat 1. 3pt quick connect unit. #5
Will Cat 0 items fit a Cat 1 3 pt hitch???
/ Cat 1. 3pt quick connect unit. #6
With bushing adapters because the pins are smaller in diameter.
/ Cat 1. 3pt quick connect unit. #7
Not sure what tractor you have. If it is a BX2200 then they don't work. The 3 pt arms on the BX2200 are too short. I bought one and then took it back.
Nice concept, just didn't work. TSC folks said not a problem and thanked me for trying.
/ Cat 1. 3pt quick connect unit. #8
opps, I have a BX22 (same as the other bx) so I am out of luck. Not biggy
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2011 Terra Riser 300D-SA Fire Plow Tractor Attachment (A61572)
2011 Terra Riser...
RING 2 STARTS HERE @ 9:15 AM (A64280)
RING 2 STARTS HERE...
Caterpillar D7G Tractor Service and Parts Manuals (A63117)
Caterpillar D7G...
UNUSED SDLANCH SDLC2533FT 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
