Cat 1. 3pt quick connect unit.
   / Cat 1. 3pt quick connect unit. #1
NewTexan
Kubota B7500
Has anyone had any experance using one of the many different brands of 3pt quick connect "brackets" that you see at TSC? I kinda like the idea of backing up to an implement, raising the lift up to the pins and flipping two levers to attach the implement. However I haven't heard if they work well or not.
   / Cat 1. 3pt quick connect unit. #2
They work well if they fit your attachments.
Problem is many times your implements need to be altered for the quick hitch to fit.
Thanks for the info. I had reason to believe that was the case. I have to move my tension chains quite a bit to switch from the box blade to the brush cutter.
I will just save my money to buy a PHD> /forums/images/graemlins/laugh.gif
   / Cat 1. 3pt quick connect unit. #4
I have one I got at TSC. All the bottom links on my equipment fit fine. I put pins in the top link so I can adjust it quicker. I've been satisified with it.
   / Cat 1. 3pt quick connect unit. #5
Will Cat 0 items fit a Cat 1 3 pt hitch???
   / Cat 1. 3pt quick connect unit. #6
With bushing adapters because the pins are smaller in diameter.
   / Cat 1. 3pt quick connect unit. #7
Not sure what tractor you have. If it is a BX2200 then they don't work. The 3 pt arms on the BX2200 are too short. I bought one and then took it back.
Nice concept, just didn't work. TSC folks said not a problem and thanked me for trying.
   / Cat 1. 3pt quick connect unit. #8
opps, I have a BX22 (same as the other bx) so I am out of luck. Not biggy
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
6 pallets of PomPoms on Rope (A53117)
6 pallets of...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Bobcat 14in. Excavator Bucket (A53117)
Bobcat 14in...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
