Cat 0 3pt hitch for a ATV on a CC 2500
   / Cat 0 3pt hitch for a ATV on a CC 2500 #1
nbtvee6
Goochland, VA
GT 2542
Has anyone modified one of those ATV 3pt hitch kits for use on a CC 2500? It looks like they just go into a standard 2" receiver hitch on the ATV.
This is one example of what I was looking at. http://www.kolpinpowersports.com/sto...s/1/products/3
I was thinking I could modify my rear bagger mounting plate by welding in some bracing and a 2" square tube to accept the ATV 3pt hitch kit.
That bagger bracket goes into the frame rails on each side and mounts through the draw bar as well. If I put bolts through the frame rails on each side through the bagger bracket and one through the draw bar I am thinking that will lock it up nice and tight to the frame.
I would love to be able to use cheap and easy to find cat 0 3 pt hitch attatchments.
Or would this idea be :eek:
Thoughts?
   / Cat 0 3pt hitch for a ATV on a CC 2500 #2
Before I bought my tractor I made a 3 point trailer to pull behind a Yamaha Rhino, with a box blade or a dirt scoop. Worked pretty well and weight was on the trailer wheels. Agrifab sells one but I made my own, used a 12v winch to raise and lower the implement.
Agri-Fab
   / Cat 0 3pt hitch for a ATV on a CC 2500 #3
   / Cat 0 3pt hitch for a ATV on a CC 2500 #5
Speaking of Cat 0 3pt hitches - does anyone have one mounted on a CC3000 series using the hydraulics? How well do they work and how expensive are they?
   / Cat 0 3pt hitch for a ATV on a CC 2500 #6
Tap Tap Tap....Hello? Is this thing on? Anyone?
   / Cat 0 3pt hitch for a ATV on a CC 2500 #7
I don't have one for a Cub Cadet 2500 but I did adapt a Kolpin 3-point hitch for a Green & Yellow Garden Tractor. So far I am satisifed with it. No problems.
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
Portable Restroom (A54865)
Portable Restroom...
4 WHEELER RACK (A58374)
4 WHEELER RACK...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
