Cat 0 3pt hitch for a ATV on a CC 2500
   / Cat 0 3pt hitch for a ATV on a CC 2500 #1
nbtvee6
Goochland, VA
GT 2542
Has anyone modified one of those ATV 3pt hitch kits for use on a CC 2500? It looks like they just go into a standard 2" receiver hitch on the ATV.
This is one example of what I was looking at. http://www.kolpinpowersports.com/sto...s/1/products/3
I was thinking I could modify my rear bagger mounting plate by welding in some bracing and a 2" square tube to accept the ATV 3pt hitch kit.
That bagger bracket goes into the frame rails on each side and mounts through the draw bar as well. If I put bolts through the frame rails on each side through the bagger bracket and one through the draw bar I am thinking that will lock it up nice and tight to the frame.
I would love to be able to use cheap and easy to find cat 0 3 pt hitch attatchments.
Or would this idea be :eek:
Thoughts?
   / Cat 0 3pt hitch for a ATV on a CC 2500 #2
Before I bought my tractor I made a 3 point trailer to pull behind a Yamaha Rhino, with a box blade or a dirt scoop. Worked pretty well and weight was on the trailer wheels. Agrifab sells one but I made my own, used a 12v winch to raise and lower the implement.
Agri-Fab
   / Cat 0 3pt hitch for a ATV on a CC 2500 #3
   / Cat 0 3pt hitch for a ATV on a CC 2500 #5
Speaking of Cat 0 3pt hitches - does anyone have one mounted on a CC3000 series using the hydraulics? How well do they work and how expensive are they?
   / Cat 0 3pt hitch for a ATV on a CC 2500 #6
Tap Tap Tap....Hello? Is this thing on? Anyone?
   / Cat 0 3pt hitch for a ATV on a CC 2500 #7
I don't have one for a Cub Cadet 2500 but I did adapt a Kolpin 3-point hitch for a Green & Yellow Garden Tractor. So far I am satisifed with it. No problems.
International 820 Platform (A50514)
International 820...
Volvo DD24 Roller (A47384)
Volvo DD24 Roller...
2023 Power Skid Steer Loader (A50322)
2023 Power Skid...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
