Caswell Powder Coating System
/ Caswell Powder Coating System #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
Has anyone used Casewwell's Powder Coating System like the one pictured here.
At only $95 it's not very expensive and could be fun to play with. Seems like it would do a nice job of painting my metal projects.
Caswell Inc. - Powder Coating System
/ Caswell Powder Coating System #3
that one looks like my old harbor freight one ive had it for about 5 years does a really good job the gun cracked off the paint cup i taped it back on that one your looking at uses the same cupp as hf i think(looks the same). the wife bought me the eastwood one for christmas ti also works good since i get all my powder from them it is easier to use eastwoods gun. get the fever anything that sits still now gets beadblated and coated.. i also got my oven from my x neighbor he had it in his truck to get rid of it win win for both of us..jon
/ Caswell Powder Coating System #4
As MrJimi stated, Eastwood has VERY good powder guns. I have the Original Hot Coat gun and the new airless one too. I prefer the airless one because I now don't need to keep adjusting pressure regulator for applying,(5-8psi), then turning up for clean-up. Also 1 less hose dangling around your feet.
Sometimes a good deal turns out to be a PITA, but then again it may work fairly well. I went with Eastwood because it is a very proven unit. Been using the original for over 6 yrs without an issue. And the airless unit is on sale for only 25 bucks more than the caswell, or the Original is even cheaper yet right now. Just my .01c (I'm too cheap for .02c, it's a fuel thing;) )
Powder Coating Guns: HotCoat and HotCoat Pro Powder Application Guns and Equipment
Thanks for the quick replies. I going to order the airless gun from Eastwood's. I already have an oven set up in my shop and a spray booth ready to use. Looking forward to using the powder coating gun. Steve
/ Caswell Powder Coating System #6
Glad to help. Just make sure you prep your parts VERY well or the powder won't stick. Also if you can swing it get some extra powder cups, 1 cup per color. Faster cleanups and color changes. I have 8 cups and still need more.
/ Caswell Powder Coating System #7
Haven't used their gun, but have had good luck with their powder.
Here is a tractor wheel center done with the Eastwood set-up:
/ Caswell Powder Coating System #8
doesn't it feel good knowing ou can do a part and it looks just as good as the pros in 30 min. tops
/ Caswell Powder Coating System #9
^^^Yep. Nice feeling doing the work yourself vs. paying someone else for something you are capable of doing.
I have been using Eastwood products for 6 yrs coating my custom gas/cargo racks for snowmobiles for 6yrs, and have had fantastic results. I have done some auto parts and misc stuff in between and have been VERY satisfied with the results of powder vs paint.
Here's a few shots of the racks if your interested.
Thanks for all the info. I am getting excited about receiving my kit now that I can see what it is capable of. Can't wait to give it a try.
2005 Chevrolet C4500 Landscape Dump Truck (A59230)
2005 Chevrolet...
Freightliner Columbia (A61306)
Freightliner...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2022 Ford Explorer 4WD SUV (A59231)
2022 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
