Castor wheel for holding up gate?
   / Castor wheel for holding up gate? #1
Rgillard
Ireland
Fiat 82-94
Hi guys,
My neighbour has asked me to make a barrier to close off the front of his silage pit. The problem is that the barrier can only swing one direction so that he can access the area. Its kind of tricky to explain. The thing is that he has a 28ft gate and the gap to be closed is around 40ft. What I was thinking was hanging this monstrous 28ft on a girder. On the free end of the gate I was going to put a heavy duty castor wheel which would be connected via a spring to ensure the castor was always in contact with the ground. On the free end of the gate I was also going to hang a small 12ft gate also. So the idea is tthat the whole gate will open in the same direction. Do you think a Cstor wheel would be up to take the weight of the two gates. Or if anyone else had another idea I would apprectiate their input.
Thanks,
Ronan.
Here is a small sketch of the yard. Might help get anidea of the problem
   / Castor wheel for holding up gate? #3
Been there. Done that.
But what I had was a situation where the gate couldn't be long enough to close the opening because it had to be tucked out of the way. A slider wouldn't work so I made a folding swing gate.
It worked fine.
I made the primary gate strong enough to carry the weight of the second gate. And of course the pipe post was set so that it carried the combination without sagging.
There was the problem with the lack of rigidity in the first gate to carry the second gate when the second gate was open ninety degrees. The person doing the opening had to help the second gate at that point. /forums/images/graemlins/tongue.gif In that situation the caster wheel should have been on the second gate instead of the first.
   / Castor wheel for holding up gate? #4
If the grade is relatively level I have another idea for your situation. Instead of using a caster consider building a triangular frame with a wheel at each end. So instead of having one wheel supporting the weight of the gates you'd have two. The hinge post will keep the gates up. And the two wheeled end on the big gate will enable the smaller gate to swing easily.
The idea is to have the end of the bigger gate strong enough to handle the weight of the shorter gate during it's whole swing arc.
If the ground isn't level you might have to replace the top hinge on the big gate with Heim (rod end bearing). Then the lower hinge needs to have either a smaller pin or a larger hole. This will allow the gate to move up and down on the end while keeping it in line.
   / Castor wheel for holding up gate? #5
Like the others.. I think the idea will work, depending on the strength and rigidity of the large gate. Castor kits are readily available.
You may want to consider a tension (guy) wire from a high point mounted at the main gate hinge post. Have that wire travel down to the top corner of the primary gate. ( should look like a right triangle.) This should offload some weight from the end of the primary gate.
Soundguy
Harry,
Could you do a simple sketch on paint so that I can fully understand your idea. The triangular frame certainly would add more stability to the gate. Would it need to castor?
   / Castor wheel for holding up gate? #7
I think Harv's idea is right on the money. I also like the addition of of the guy wire, however if you were resting the main gate on the double castor wheels, the ground should bear the weight of the wheels just fine, unless it very muddy. Perhaps instead of castor wheels which might dig into soft ground, you used some very small tires or wheels??? Something that would spread the load of the primary gate over the soft ground. Picture a trianglular plate with the apex pointing up. Then put a wheel at each of the bottom corners. Looking at the gate "end on" (the red post in the photo), the bottom of the gate would sit on the apex of the triangle. Not trying to steal your thunder here Harv, but I had an image program open on the desktop. Is this what you are describing somewhat?
Ken
   / Castor wheel for holding up gate? #8
Ooops...here's the picture.
Ken
   / Castor wheel for holding up gate? #9
You got it Ken, darn, either I'm getting better at 'splainin' or ya'll gettin'n better at cipherin'. And your picture is definately worth more than my thousand words. /forums/images/graemlins/blush.gif
I'd like ya'll to think about something.
If you run that guy wire from the top of the post aren't you putting more leverage against the footing of the post?
But if you put that guy wire from the lower corner of the latch side of the gate back up to the upper frame near the high hinge aren't you accomplishing the same thing without the additional pressure on the footing?
Just a thot, harvey
   / Castor wheel for holding up gate? #10
I think that might put more stress on the gate itself. With the guy wire to the hinge post, and a castor, you can get by with a much flimsier gate. I've not seen this fellows 28 ' gate.. but most of the big gates I've seen were simple thin walled tube.. and not monstrously strong, save being able to carry their own weight.
You also wouldn't want the guy wire to carry the entire load of the gate.. but simply offload a few pounds, and let the wire be under some tension, but not full loaded.
Sure, this is adding a bit of stress to the post carrying the gate.. but then when i do fencing, the gate post is the biggest post I have, including the corner posts. I generally like 6-8x8 corner posts.. and bigger gate posts.. perhaps telephone pole material even.. whatever is big that I can lay hands to when I'm fencing. Fairly easy to get sizeable round timber around here, as lots of people like those 'big ponderosa' style ranch entrances.. materials in other regions may not be so easy to come by.
Soundguy
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A51572)
2008 Sterling...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2020 JOHN DEERE 333G SKID STEER (A51246)
2020 JOHN DEERE...
2021 New Holland C327 Compact Track Loader (A53472)
2021 New Holland...
