cast iron repair
/ cast iron repair #1
jpdriver1
howdy fellow members, I am in need of suggestions for repairing a broken cast iron drill press.
JB weld, liquid steel ect...
thanks
/ cast iron repair #2
I have welded cast iron in the past but the trouble is when it cools, it can sometimes crack. The answer is to heat it and get it really hot before welding, then let it cool slowly. I would be tempted to ask around to see if a local guy can weld it. JB Weld etc might not last long.
/ cast iron repair #3
Depending on break and use of press, I have serious doubts any "glues" are going to work... A good welder (arc) with cast iron rod and pre heat and extended cooling can probably fix it, and another possible fix may be to have it oxy/acet brazed with "brass" rod again proper preheat and slow cooling is necessary....
A picture of "break" my help to get proper advice on fix...
Dale
/ cast iron repair #4
I've had excellent results welding cast iron with ArcTec 223 welding rods.They have 28% stretch which means the cast doesn't crack. I would warm up the cast piece to weld it and then after welding cover the piece with insulation to let it cool slowly overnight.
/ cast iron repair #5
if you like your drill press and want it 100% ... 2 choices
find a replacement part
send it to a cast iron repair shop. I have sent out a couple parts and both came back perfect and looked like new parts.
Not cheap. have to pay shipping both ways but its fixed.
/ cast iron repair #6
I have had excellent results welding cast with nickle rods, weld 3/4 to 1" and walk away till it cools then do another until it is all sewn up. 20 years ago I built a bell housing for an old M715 5/4 military truck so we could installed a 250ci Chevy in place of the OEM engine, still going strong the last I heard.
/ cast iron repair #7
John0829 is exactly right, and use even shorter segments of weld if you have a small area of repair. This works well and you can youtube it.
/ cast iron repair #8
I have an antique wood stove with a very thin C.I. door.
Is it likely that those ArcTec 223 rods would work?
I would not attempt it, but could perhaps ship it to someone who could do a proper weld repair.
C.I. is only about 1/4"- 3/8" thick.
/ cast iron repair #9
Do you have an address/phone number for that shop?
/ cast iron repair #10
Around here we have an old time blacksmith welder that has done miracles for me.
He seems to like OxyAcc for cast iron vs Mig/Tig.
He's fixed many things 4 me including an exhaust manifold that he welded in situ.
That was on my father's car that I borrowed and even 3 years later Dad never was aware of my mishap.
I also watched him repair an aluminum water tank for my RV with the torches.
He was a true artisan!
With the torches I guess that addresses the preheating issue and the brass flows just nicely.
Actually I once researched the PSI's and brazing joints are really high up there compared to Mig/Tig and fancy rods.
Now I'm a DIY welder (torches and rod) and with proper heat and penetration so far none of my joint have let go.
Not all pretty but I do get decent penetration.
Like trailer hitches, frame repairs and all sorts of crazy concoctions.
I grind, clean and use high amps to get things really glued together.
When I see nice heat lines on the backside of my work pieces (and ,LOL, no burn thru's) I know the pieces will stay glued.
LOL, my first welder was a homemade converted stepdown transformer.
Heck I've made a few just for fun by re winding old found transformers.
Last DIY was using a large garage booster charger as I liked the core design.
Being a 110 charger the welding output is limited to 3/32 rods but it works and stick stuff together. Not to build bridges.
/ cast iron repair #11
Fried1765 You would be amazed to what the small portable welding companies can do, you might look for one to come to you place and weld it up. Get an idea on price first!
/ cast iron repair #12
Yes it would. They weld similar to a Lincoln 7018 A/C rod on an A/C welder. Kind of sticky but flow nice once you get them going. I use a piece of scrap metal on the welding table and warm them up a bit before moving onto fussy welding. I would use a 3/32 rod.
/ cast iron repair #13
Be sure to drill a small hole at the end of the crack before welding or brazing. Otherwise the crack keep going.
/ cast iron repair #14
Oh yes!
I am very familiar with stop drilling,..... from history in the aviation community.
I just need to find the right guy to do the repair, and ship the small C.I. door to him.
/ cast iron repair #15
Cast Iron Repair Specialist Inc
16129 Smokey Point Blvd, Marysville, WA 98271
Phone: (360) 657-7660
You wont be disappointed he does very nice work
/ cast iron repair #16
Thank you!
I will contact him.
/ cast iron repair #18
Yep! that's called 'stop drilling'.
In aviation that was common practice on skins and plexiglass windshields as well.
I also found it worked well on my damaged car plastic bumper shield.
/ cast iron repair #19
take a couple pics and ask for a number to send them to. Then he can give you a much better estimate on the repair and time to do it.
Thanks again!
/ cast iron repair #20
ALL: I've seen some repairs made to some big vises by the owner of CAST IRON REPAIR about an hour north of SEATTLE and OMG that guy does a great job.
if you do want to braze something yourself yes heating it up and either sticking in sand or wrapping in a heat blanket are good ideas. another option is to heat up your project in the BBQ, weld it, then put back in the BBQ and lower the temp inside your BBQ.
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
John Deere 1025R (A62177)
John Deere 1025R...
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
