CAST-IRON Pan Cooking
   / CAST-IRON Pan Cooking #1
BrianDT
I picked up a Lodge brand 5 piece set of cast iron pan off from Amazon a few months ago and I have been having a blast with it.
Lodge 12 inch Cast-Iron Skillet
Since its cold out, its taking the place of the grill for the winter.
I have been watching some videos and learning how to use it correctly.
Have any of you used the pan in my link and if so, how has it been working?
Also, do you guys have any suggestions for cooking steak in a cast iron pan?
   / CAST-IRON Pan Cooking #2
There are two kinds of people in the world:
Those that can cook with cast iron and those that.... oops! wrong thread! My bad.
   / CAST-IRON Pan Cooking #3
I have found "seasoning" cast iron pans with several coats of FLAX OIL to be superior to any other treatment. I use edible "Barlean's Flax Oil, 100% organic". Flax oil is readily available in health food stores. A small container will prep pans your lifetime.
Flax oil is used in the manufacture of paint, which may explain its longevity as a pan treatment.
After flax oil treatment you can use soap and water washing pans and slickness does not disappear.
   / CAST-IRON Pan Cooking #4
We do venison tenderloin medallions, 2 mins / side in good butter, 4 minutes and your done. Can cut them with a fork... Thanks for the video, might have to try venison steaks that way. :thumbsup:
   / CAST-IRON Pan Cooking #5
Those cast iron pans are inherited down here in the south. I have my Grandmother's and wouldn't trade it for anything.
After years of cooking pork tenderloins on the grill, last fall I saw a recipe using a cast iron skillet, and my family loved it.
Take your tenderloin and pound it down on the thicker area so that it is about the same thickness.
Cut it in half if needed to fit in the pan.
Get your pan on medium high, add a small amount of oil, maybe 3-4 tablespoons, and sear the tenderloin to a nice brown on all sides, about 3 minutes per side. Lower the heat to low-medium and put a cover on the pan and allow it to continue to cook about 7-8 minutes.
In a measuring cup combgine:
about 1/4 cup tiger sauce
1/4 cup of some fruit preserve like peach, blackberry or raspberry
a couple tablespoons of soy sauce
If you like it spicy, add a half teaspoon of red pepper flakes.
Once the tenderloin has reached 140f with a meat thermometer (or what I like about medium) pour the combined mixture over the tenderloin in the pan and turn the tenderloins over a couple of times to complete coat them.
Take from the pan to a cutting board and cover lightly with foil for at least 7-10 minutes to rest.
Turn up the temperature on the remaining pan sauce to med-high and stir to release any bits and good stuff on the pan and to reduce the liquid a bit, be careful not to burn the liquid if it has thickened much as the sugars in the preserves can easily scorch if not careful.
Then slice it about 3/4"-1" thick, and server immediately with the pan sauce over it.
Yum.
   / CAST-IRON Pan Cooking #6
I had an old GF and cast iron was all she would use...she wouldn't eat if it was from a Teflon coated pan.
Your food can cook a long time after you remove it from the heat
   / CAST-IRON Pan Cooking #7
My Dad cooked all the steak when we were growing up and never used anything other than a cast iron frying pan. Crisco or olive oil, heat to just smoking, put seasoned steak on. Turn over after several minutes. Cooks quicker than you think. Spatters everywhere.
   / CAST-IRON Pan Cooking #8
My fiancee loves the old cast iron plans she inherited from her grandmother, uses them all the time. I bought her some Lodge CI pans to round out her collection, she hates them and won't use them. I have no idea what the difference is, she can't explain it, but they sit tucked away in a bottom drawer, used only one time each.
   / CAST-IRON Pan Cooking #9
I have the same 12" Lodge pan, and an 8". The 8" is always a bit slicker it seems. I don't do any special seasoning, but I never use soap either.
Can't beat CI for searing meat. For splatter control those fine mesh screens help. Getting a non-stick pan hot enough to really sear will destroy it pretty quickly.
   / CAST-IRON Pan Cooking #11
I love the way my handed down cast iron pans cook...but I rarely use them because they take so long to heat up...
FWIW...
Iron pans have to be "seasoned" correctly to be basically stick free...and to maintain the "seasoning" you are not supposed to use typical (grease cutting) detergent...so you have to be careful if someone else is helping out doing dishes...!...I was also taught that they should be dried with heat after cleaning rather than than a towel/air etc...
   / CAST-IRON Pan Cooking #12
I love making breakfast (bacon and eggs) corn bread and grits on a CI pan outside on the side burner of the grill especially if it has snowed the night before. We have a covered outside porch.
   / CAST-IRON Pan Cooking #13
My wife says the same thing and loves the hand -me-down, but not the newer stuff. Here's part of the answer about the difference between old and new: -
" The Reality: The material may be the same, but the production methods have changed. In the old days, cast iron pans were produced by casting in sand-based molds, then polishing the resulting pebbly surfaces until smooth. Vintage cast iron tends to have a satiny smooth finish. By the 1950s, as production scaled up and was streamlined, this final polishing step was dropped from the process. The result? Modern cast iron retains that bumpy, pebbly surface.
The difference is more minor than you may think. So long as you've seasoned your pan properly, both vintage and modern cast iron should take on a nice non-stick surface, but your modern cast iron will never be quite as non-stick as the vintage stuff."
   / CAST-IRON Pan Cooking #14
Love my cast iron. Use the skillets often. We use the dutch oven when we camp. Someone posted the link to Byron's site. His recipes are great. We have made a lot of them.
   / CAST-IRON Pan Cooking #15
I have seen a big difference between Lodge and "other" brands which are much less expensive and imported. At least in Dutch ovens. We got our son a 10" camp Dutch oven a few years back; I think it was Stansport. It is ok, but not for cobblers etc where you want no stick. Or Lodge(12") is much nicer finish.
We picked up Lodge 12" for the Scout troop; they are holding up great considering the boys do not care for them like I would our own(I take my own on camputs with them).
   / CAST-IRON Pan Cooking #16
If you want to search the antique or second hand stores for good cast iron look for Griswold. That's good stuff.
For cooking steaks in the winter we use the Lodge reversible griddle/grill.
   / CAST-IRON Pan Cooking #17
We use cast iron skillets and dutch ovens.
   / CAST-IRON Pan Cooking #18
There's no question the OLD CI is smoother than the new CI and of the new CI, nothing is better than Lodge. All the "other" brands normally found are from china and are REALLY rough... I have NO use for it!
I love my old CI! even though I do have some Lodge that is usable...
SR
   / CAST-IRON Pan Cooking #19
I frequently do eggs in my CI pan. I take the eggs out, wipe out the eggs from the sides (adding a little water if needed to steam off anything that was stuck), then put back the pan on the stove where I wipe the inside down with a little oil (just enough to leave a sheen) and let it sit till cool.
Aaron Z
   / CAST-IRON Pan Cooking #20
Those cheap CI pans can be sanded smooth, just be sure to use proper sane paper with garnet or black oxide paper NOT aluminum oxide paper. There are some flap wheels that can be used also to smooth it out polish it some but you need to "Blast" it so the surface is slightly rough to open up the pores to accept lard seasoning. )do not use silica based sand to blast it use bead or garnet or slag.
M
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2002 FORD F-350 XL...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Booster Cables (A59230)
Booster Cables...
