CaseIH Farmal 65A
/ CaseIH Farmal 65A #1
Msudairyfarmer
Case IH
Hi Everyone,
Have a 2012 65A that we keep around the farm for light duty work. It is lower hours (under 1200) and we have started having an issue with it today. After about 45 mins to an hour of run time (this time it was on a rotary rake), it will begin to churn smoke and lose power. Once you let it sit awhile and fire it up, it will run fine for a bit and do it again.
We changed all air filters (inner and outer), in-line fuel and screw in fuel filters. Still having the same issue. I had read that the silicone fuel line could be a culprit of collapsing once warm, but have not investigate that.
Anyone have any suggestions or experience with this happening?
Thanks in Advance!
/ CaseIH Farmal 65A #2
You could be sucking up junk from your tank over & over again.
If your tank has a drain or you can vacuum pump drain it, try it. Might have water & crap in the bottom.
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2014 WACKER NEUSON (INOPERABLE)  HIF690 (A68842)
2014 WACKER NEUSON...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
