Case wont move
/ Case wont move #1
kevphi
case 450 d0zer 1943
Hi have case 450 d dozer that will not drive, changed all transmission oil filter and checked charge pump filter and washed it. Oil apears to have lots of AIR in transmission. Toque compression gauge reads up to 25 and 50. Transmission gauge is about 150 checked for possible air leaks can,t find any. Any advice please.
/ Case wont move #2
Hi Kevphi. Welcome to the club. I am experiencing the same problem. My research indicates that it could be the rubber hose that develops a crack (allowing air to enter the system) down near the transmission housing or potenitally a worn charge pump, or the shaft seal on the charge pump. Like a rookie, I removed my charge pump thinking I would get a rebuild kit and forgot about the bottom hose shank. Next week I am going to remove the rubber hose section and replace. I might also replace the charge pump shaft seal and any associated O-rings before I spring for a new reman. unit at $265. Let me know how it goes and I will do the same.
BIGRZBTR
/ Case wont move #3
When you say 150 are you talking about the pressure gauge on your dash? If so I think that's the output of your charge pump. I think mine reads 175. When my charge pump got worn I would have to park the dozer facing downhill. If I didn't that gauge would read zero and it wouldn't move until I used the backhoe to lift up the rear.
/ Case wont move
Hi crazyal, trying to work out this computer thing easier to work on old stuff.It's the tranmissiom gauge that reads 150, and the toque converter gauge reads 25 and the temp gauge stays in the green. When engine is stoping toque converter maks a strange noise.
/ Case wont move #5
Does the floorboard lift up, it does on mine. You can see the driveshaft. I'm not sure if the newer 450's (mine is a 450b) are different but on mine the torque converter is mounted to the back of the engine but the high/ neutral/ low reverse box is under the seat with the driveshaft connecting them. I would think a simple check would be to see if the driveshaft is spinning when you try to move. If it stops turning then I would think you have a torque converter problem. My dozed doesn't have a torque converter gauge.
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2022 EZ-GO ELITE...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2010 Club Car Electric Cart. (A64557)
2010 Club Car...
