Case VAC Problems
   / Case VAC Problems #1
mhachez
Ontario
Case VAC 14
Hi,
While working with my VAC 14, I noticed that it wasn't working properly. I then decided to check the oil and found some antifreeze and also it sounded like the motor was only running on 3 cylinders instead of 4 but it never had smoke coming out of exhaust.
As I started to drain the oil, I noticed that there was some pieces of the bottom part of the piston. It looks like only one piston blew.
Does anyone know what could cause the bottom of the piston to blow up like that? Any suggestion?
   / Case VAC Problems #2
Is their suppose to be power on both sides of the coil?
2025 JMR 40in Single Cylinder Hydraulic Grapple Rake Mini Skid Steer Attachment (A50322)
2025 JMR 40in...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A51572)
2004 International...
Orange Signal Trailer (A50121)
Orange Signal...
Unused 2025 CFG MX20R Mini Excavator (A50322)
Unused 2025 CFG...
NEW Fork Extensions (A53002)
NEW Fork...
