Case regulaor
/ Case regulaor #1
rawdflow
case 580 ck 1958
Ok hi to all
I have acse 580 ck 1967 , it as a regulator a part from the generator there is 4 pins 5 wires attached to it, thing is the batteries dies all the time
So whent on checking the voltage at the red wire from the generator = 7 to 12 volt not stable at idle speed so i cleaned and replaced all wires
When i puted back the red wire that goes to the generator it sparked, I was thinking that I probably put the wire wrong?
Anyway cant find a proper diagram about this :(. Im geting a new regulator tomorow and not sure how to wire it yet.......
Thanks for any advises and or help
Jc
/ Case regulaor #2
i think i'd be geting a service manual for that tractor.
some wires you can guess. ie.. field and armature ground and load.. 5th wire?
