Case jx 80 running rough
   / Case jx 80 running rough #1
olerebb
jd 3020
Good Day
I have a Case JX80 tractor cab, fwd with FEL. While cutting hay it starts to run rough and emits blue or gray smoke from exhaust, fumes from smoke smell really bad and its wants to heat up more than usual. Where should I start looking to find the problems?
   / Case jx 80 running rough #2
Blue smoke usually indicates oil getting past the valve guide seals. Running rough is a fuel issue. Have you changed your fuel filter? Do that first, then let us know how it runs.
Could be an injection pump issue, but do the cheap & easy stuff first.
   / Case jx 80 running rough #3
I've seen a JX 95 that acted like it was running out of fuel, had the cab sitting on and pinching the fuel line that caused the problem.
SR
2017 Kubota M5-111D 105HP Agricultural Tractor (A52377)
2017 Kubota...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55218)
Kubota SVL65-2...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
