Case / International Dx35 Adusting the Hydrostatic transmission.
   / Case / International Dx35 Adusting the Hydrostatic transmission. #1
okteach
Atoka, Ok
Case/international DX35
I have a 2004 Case/International Dx 35 tractor and when I let the forward or reverse pedal go the tractor will slowly keep going forward. I can push on the reverse pedal about a quarter of an inch and it stops moving. I tried to figure out how to adjust it but to me it will have to be adjusted in the transmission. This problem just started, the tractor has 268 hrs. on it. If some one could help I would appreciate it.
   / Case / International Dx35 Adusting the Hydrostatic transmission. #2
The problem is called creeping and in most cases it can be adjusted from the outside on the trans. There is an eccentric cam underneath the right fender that you can adjust.
There is also a damper (shock) that hooks to the cam. Sometimes it will go bad and not let it return to neutral.
Thanks for the reply. I looked and looked and finally found the cam. I think adjusting the cam a little is all that is needed. Thanks again for your reply.
   / Case / International Dx35 Adusting the Hydrostatic transmission. #4
Welcome from Wisconsin
   / Case / International Dx35 Adusting the Hydrostatic transmission. #5
Welcome to TractorByNet!
I moved your thread to the Case-IH forum. :)
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
7021 (A50322)
7021 (A50322)
JOHN DEERE 333G LOT NUMBER 259 (A53084)
JOHN DEERE 333G...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
