Case IH starter not engaging
/ Case IH starter not engaging #1
double hunter
Ford 1715
Just bought a Case/IH 255 at an estate sale, got a heck of a deal, anyway the starter is not engaging, it will spin but not engage the flywheel, been sitting up for a couple years, any suggestions as to what to check,
/ Case IH starter not engaging #2
I had that problem with my Ford.
Pull the starter, and check for rust on the bendix gear and shaft. You likely will be able to break the bendix loose, and it should work just fine. Perhaps a little WD40.
/ Case IH starter not engaging #3
Low battery, bad cables, bad connections will also cause the bendix to not throw the gear out all the way. Could be a weak starter too.
But as mentioned........take it off and clean and lube.
/ Case IH starter not engaging #4
Good point about the low battery or cables.
Tractors are often easy to touch the starter with (and selenoid) with jumper cables, although loaders often get in the way.
2008 Unverferth 220 Rolling Harrow (A63116)
2008 Unverferth...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
JOHN DEERE 4 BOTTOM PLOW, 3PT (A62130)
JOHN DEERE 4...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A61165)
2005 Hino 268...
