Case ih mx 285 hydraulic remotes wont release
   / Case ih mx 285 hydraulic remotes wont release #1
Uffelmann
Red Bud, IL
CIH MX 285
When we put the hydraulic remote in detent they don't release... We have the timer set for 3 seconds and have the dial in the arm rest set to 1. Any suggestions on how to get this working?
   / Case ih mx 285 hydraulic remotes wont release #2
Not familiar with MX 285 hydraulics but on most systems With the valve in detent you applying pressure to the work ports which will make it next to impossible to disconnect the quick disconnects. Usually the lever is in the spring centered position and any and all weight is removed from any implement is removed before disconnecting the remotes.
   / Case ih mx 285 hydraulic remotes wont release #3
Sounds like the timer is not working. IRC on the 285 you can turn the timers off to run scrapers and vacs that require constant flow. A lot of times it needs to use the case dump on the return side to get max flow.
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
1991 Trail King Trailer (A55973)
1991 Trail King...
NEW Wolverine Sid Steer Vibratory Rollerr (A59000)
NEW Wolverine Sid...
