Case IH JX75 Hydraulic Issue
   / Case IH JX75 Hydraulic Issue #1
Beef99
Fulton, Kansas
Case IH JX75
I was mowing hay last night and everything seemed to be going ok, until I tried to raise the mower. The hydraulic arms would not raise, I then tried to raise the FEL and it wouldn't raise either. I needed to finish mowing the field so I kept going and kept trying the hydraulics every once in awhile. Finally a while later everything started working again. Not sure what is going on, anyone have any suggestions. Also, I have noticed lately that the power steering is not as effective as it normally is (little harder to steer).
   / Case IH JX75 Hydraulic Issue #2
Check your fluid levels, check screens if you have them,check filters, check that the valves are not in relief .
Use a pressure gage to determine if and where you have pressure and how much.
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
Tarter 4' 3 pt Box Blade (A50515)
Tarter 4' 3 pt Box...
2016 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
2002 Trotwood Trailer (A50515)
2002 Trotwood...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
