Case IH JX75 Hydraulic Issue
   / Case IH JX75 Hydraulic Issue #1
Beef99
Fulton, Kansas
Case IH JX75
I was mowing hay last night and everything seemed to be going ok, until I tried to raise the mower. The hydraulic arms would not raise, I then tried to raise the FEL and it wouldn't raise either. I needed to finish mowing the field so I kept going and kept trying the hydraulics every once in awhile. Finally a while later everything started working again. Not sure what is going on, anyone have any suggestions. Also, I have noticed lately that the power steering is not as effective as it normally is (little harder to steer).
   / Case IH JX75 Hydraulic Issue #2
Check your fluid levels, check screens if you have them,check filters, check that the valves are not in relief .
Use a pressure gage to determine if and where you have pressure and how much.
1263 (A50490)
1263 (A50490)
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
Set of Ag R4 Wheels and Tires (A52128)
Set of Ag R4...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A52128)
2023 PJ 49FT...
